1996 Volvo 960 No codes, engine has rough idle
158,711 MILES • 6 CYL • 2WD • AUTOMATIC
METRIC1000
  • 6 POSTS
This car is driving me crazy! It has no trouble codes, but it hesitates almost stalling when you accelerate. Sometimes popping like the old cars use to do when the timing was way off. What could it be? Can you point me in a good direction?
Apr 12, 2008 at 9:00 AM
  • 75,988 POSTS
When was the last time it had a major tune-up?
Test the throttle position sensor and fuel pressure to rule out the fuel filter/pressure regulator/fuel pump
Apr 12, 2008 at 9:23 AM
METRIC1000
  • 6 POSTS
[quote:d74e94f02e="rasmataz"]When was the last time it had a major tune-up?
Test the throttle position sensor and fuel pressure to rule out the fuel filter/pressure regulator/fuel pump[/quote:d74e94f02e] I am going to try these options and let you know.....
Apr 12, 2008 at 10:06 AM
