1996 Volvo 960 Missfire
1996 VOLVO 960
80,000 MILES • 4 CYL • 2WD • MANUAL
HUNT60BR
This 2.5 lt 24 valve, Volvo miss fires at idle (>1000RPM) All systems check out okay. ECU returned as "no problem found"
Dealer checked vehicle without success, including intakes manifold and electronics. No fault codes exist.
It is possibly miss firing at higher RPM, but doesn't appear to have loss of performance, or fuel penalty.
Suggestions please.
Apr 17, 2008 at 10:52 AM
BMRFIXIT
  • 19,053 POSTS
Misfire is monitored by the ECU and misfire will cause a check engine light on and will store a code in
if you don’t have any then look for other causes that is causing the unstable idle for you
check motor & tranny mounts
Apr 17, 2008 at 11:09 AM
