fuel filter change
GINNYUNDERWOO
How do you change the fuel filter on this car?
Jul 9, 2010 at 12:55 AM
  • 55,694 POSTS
The fuel filter is located under the car near the rear of the car. You will need to jack the car up safely here is a guide to help you with that.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
This next guide will give you an idea of what you are in for when changing the fuel filter.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Here is a video to help you remove the lines from the filter even though it is a ford they are the same connectors.
https://youtu.be/Boi0DPXVHbM
Removal
Remove fuel filter from hose.
Slacken off quick-release connectors from fuel filter using an 17 mm open wrench.
Remove Torx 25.
Open the hose clamp.
Pull out fuel filter to the right.
Check out the diagrams (Below)
Cheers, Ken
Dec 1, 2017 at 4:51 AM
BE RIGHT
Engine Performance problem
1994 Volvo 960 6 cyl Two Wheel Drive Automatic 230000 miles
Is there a fuel filter at the top of the tank &/or Is there one in the tank ?
Dec 1, 2017 at 4:51 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Fuel filter is located under right, rear of vehicle, in front of axle.
There are 2 fuel pumps however, one inside tank.
