1995 Volvo 960 Replacing Driver-side headlamp
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOUGLASBENNETT
Trying to replace driver-side headlamp... Stuck! Need specific instructions, please. Does the lamp wiper assembly have to be taken off lamp? If so, how in the world do you make this happen. Seems impossible to get to. Having a really hard time. Thanks.
May 25, 2010 at 4:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Disconnect the negative battery cable.
Release the headlight trim, using the applicable method below.
If equipped with plastic screws, rotate them 1 / 2 turn, then remove the trim.
If equipped with a clip at the top center of the trim panel, squeeze the two sides together, and pull upward to release the trim.
Unfasten the 4 small screws holding the retainer, then remove the retainer and the headlamp.
Unplug the electrical connector from the rear of the headlamp.
Installation is the reverse of removal.
May 26, 2010 at 4:47 PM
