Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volvo
960
Engine
Symptoms
Overheat
1995 Volvo 960 OVERHEATS
1995 VOLVO 960
221,898 MILES • 6 CYL • 2WD • AUTOMATIC
RSIMONS
MEMBER
1 POST
AT START UP WATER SHOOTS OUT OF THE OVERFLOW TANK CAUSING THE CAR TO OVER HEAT. THE WATER PUMP DOES NOT SHOW VISIBLE WATER LEAKING PROMBLEMS
Sep 12, 2010 at 5:26 AM
Experienced Mechanic
Try replacing the thermostat and go from there-
Sep 12, 2010 at 9:29 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
