My turn signals and flashers do not work. The bulbs and fuses appear to be fine. Any ideas?
Dec 29, 2009 at 4:23 PM
BLUELIGHTNIN6
✓Experienced Mechanic
fuses and bulbs can look good but still be bad. need to test the bulbs and fuses # 15, 17 and 19. If fuses and bulbs test good then suspect faulty flasher, located in the ront seating area, center, under dash, mounted below ashtray cavity
