1994 Volvo 960 Headlight assembly replacement
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIM BLU
I have a cracked LH headlight. How do I replace the assembly? Thanks
Sep 12, 2008 at 10:19 PM
IMPALASS
  • 3,112 POSTS
Hello, hope this helps
https://images.2carpros.com/forum/automotive_pictures/248015_headlamp_1.gif
Disconnect battery ground lead. Remove grille. Separate turn signal cluster from headlight (see illustration) by releasing the catch between the two holders. Remove holders and bulbs and place in engine compartment. Remove connections to headlight housing and wiper motor. Remove the four screws holding headlight housing (see Illustration). Disconnect water hose at check-valve. Remove headlight.
Oct 16, 2008 at 3:30 PM
