1993 Volvo 960
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
LOCKNESSM
I have a small leak in my proportional valve. The leak appears to be at the bottom of the valve. About every 3 days my brake fluid drops down below minimum. Can the leak be repaired or do I have to replace the valve itself?
May 9, 2009 at 1:30 AM
JIS001
  • 3,412 POSTS
Check the lines and make sure they are not loose. If lines are secured and it is the valve leaking then you will need to replace the valve.
May 10, 2009 at 6:27 PM
