1994 Volvo 940 Won't start
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
JZK77
Replaced the fuel filter. In doing so a wire came off the fuel pump, it has been put back on. But now the car won't start. Just grinds like it wants to, but nothing happens. Have checked both # 1 and 11 fuses, no problem there. What else could it be?
Oct 4, 2010 at 9:40 AM
JIS001
  • 3,412 POSTS
Make sure wire terminal is secured in connector and verify that you did not bend a pin when you reinstalled it.
Oct 4, 2010 at 12:50 PM
BURNINGFIRE
  • 10 POSTS
you might want to check your crankshaft positioning sensor also. It is located below the distributor bolted to the top of the tranny housing by a 10mm bolt and the cable runs up the fire wall. A real easy fix.
Aug 5, 2011 at 6:30 PM
