1994 Volvo 940 radiator cooling fan
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
PAPABULGE
Fan will run when jumped from battery. Will not run when supposed to. Have replaced temp. sensor on engine block. Have replaced relay by battery. On opening relay box, found that contacts are not being pulled in. help also checked fuses
Apr 12, 2010 at 3:13 AM
KHLOW2008
  • 41,812 POSTS
Hi papabulge,
Thank you for the donation.
There are 3 different cooling fan systems,
1. LH-Jetronic
2. Regina
3. Turbo.
Which is the system used in your vehicle?
Apr 12, 2010 at 7:49 AM
PAPABULGE
I don't know if it's LH-Jetronic, Regina or Turbo.
What I do know is the Engine is "B230F"
Evaporative Family: RVV1058 by POA
Engine Family: RVV2.3 V7 GAEA
Hope this helps
Apr 12, 2010 at 8:57 AM
KHLOW2008
  • 41,812 POSTS
I believe your engine is not turbo charged and it is either LH-Jetronic or Regina. The engine cooling fan relay is located on top of radiator. It is a 5 terminal relay, you mentioned replacing it, did you get the correct one? Here is a schematic of the cooling circuit.
https://images.2carpros.com/forum/automotive_pictures/192750_CoolingFan94REgina940Fig8_1.jpg
Apr 13, 2010 at 12:20 AM
