1994 Volvo 940 Oil leak from distributor
1994 VOLVO 940
KARENLR
Engine Mechanical problem
1994 Volvo 940 4 cyl Automatic 98,000 miles
I just had my timing belt and water pump replaced, plus transmission service completed. It only used to leak coolant/water. Now, it leaks motor oil. I went back to the mechanic and he said it needs a new distributor O-ring to fix the leak. Why would this suddenly happen after mechanical work? Are there any special instructions for replacing an O-ring besides following a vehicle manual?
Aug 23, 2010 at 8:53 AM
Mark the distributor housing to the block and the position of the rotor direction to the cap tower-pull it out and replace the O-ring
Aug 23, 2010 at 10:20 AM
