1994 Volvo 940 Oil leak
1994 VOLVO 940
13,000 MILES • 4 CYL • 2WD • AUTOMATIC
MASSAGE1
I have a 1994 Volvo 940 Turbo. Recently had the ignition coil, dist cap, ignition rotor & high pressure fuel pump replaced. A week later drove car to work and noticed an "burning oil smell" when car stopped. On the way home the oil light flickered on & off, so pulled over and put in almost 5 quarts oil. Next day drove it and the oil light came on again- checked the oil and it was empty! Checked the oil pan plug and filter and both look fine - oil is all over the undercarriage and on the engine block but I cannot figure out where the oil is leaking.
Dec 28, 2008 at 11:32 AM
  • 31,937 POSTS
Hi there,
Wash the engine down as best you can, top up the oil and run the engine, the oil leak should show its self quickly as a drip under the engine, trace it back to the source, i would be checking the rear main oil seal and the back of the rocker cover and the oil pressure switch, start here.
Mark (mhpautos)
Dec 28, 2008 at 11:40 AM
