1994 Volvo 940 ignition chime won't shut off until key is p
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
DADDYJIM
I cleaned the battery cables and when reconnecting, caused some sparks. Since then the ignition chime will not turn off. (Very Annoying). I checked and pulled all the fuses and that didn't help. Im selling the car and am looking for a quick, easy fix. Any suggestions? (cut or pull the correct wire maybe?)
all doors are closed and seat belts checked so that is not causing the chime. It has to be ignition key related
Mar 2, 2008 at 3:35 AM
DADDYJIM
[quote:4c6d5e4e0f="daddyjim"]Electrical problem
1994 Volvo 940 4 cyl Two Wheel Drive Automatic 89000 miles
all doors are closed and seat belts checked so that is not causing the chime. It has to be ignition key related[/quote:4c6d5e4e0f] Thank you in advance :
Mar 2, 2008 at 3:38 AM
