1994 Volvo 940 Fan Blower
150 MILES • 4 CYL • 2WD • AUTOMATIC
SPOKE
Fan blower does no turn on checked fuse in console how do I trouble shoot the blower not working?
Oct 7, 2009 at 7:27 AM
JDL
  • 16,098 POSTS
My info show fuse 11-16-- 30 amp, did you check fuse circuit with a testlite? Should be hot when you turn on the key. You can also take the connector loose from fan, turn on controls, check connector for voltage and ground.
Oct 7, 2009 at 8:18 AM
