1992 Volvo 940 Where is the fan motor resistor located
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
JWALLACE314
  • 11 POSTS
The AC does not work, so I had it checked out by the import mechanics. Because the multi-position blower switch only works on 1 speed they recommended starting with a blower resistor. Everything else works: AC compressor, holds coolant, but the switch just won't turn the compressor on. I purchased the blower resistor, but need to know where it is located on this Volvo. Also where is the associated wiring harness?
Jul 21, 2008 at 1:15 PM
  • 75,988 POSTS
The AC/Heater blower motor resistor is located on right side of dash behind the glove box- also see below-
https://images.2carpros.com/forum/automotive_pictures/12900_resistor_5.jpg
Jul 21, 2008 at 1:28 PM
JWALLACE314
  • 11 POSTS
Okay I found the blower motor resistor and changed it out. If you remove the glovebox first it is very easy to see the resistor. So now the blower motor has all 5 speeds but the AC compressor still will not turn on. The mechanic said the compressor works and the unit holds coolant. Any additional trouble shooting direction would be appreciated.
Jul 26, 2008 at 3:37 PM
JWALLACE314
  • 11 POSTS
I need additional information about why the AC compressor may not be turning on. See previous post for details
Jul 31, 2008 at 3:00 PM
KHLOW2008
  • 41,812 POSTS
Hi jwallace314,
1. You need to check if there is sufficient freon in the system.
2. Is power being supplied to the compressor?
3. Is the compressor relay working?
4. Is the AC compressor On/Off switch ok?
Aug 16, 2008 at 7:08 AM
