1992 Volvo 940 Gas Smells
1992 VOLVO 940
YUKIONNA
Smells problem
1992 Volvo 940
Ever since my mechanic replaced the fuel pump, I smell gas while I'm driving. I went back to him, but he told me that there's no leak. He didn't do any furthur action. Could this be something related to the replacement of my fuel pump?
Oct 29, 2010 at 8:48 PM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
Hello .. thanks for the donation.. much appreciated
I would have the mechanic check nothing has been left loose (fuel lines/sealing ring etc.) also there are no cracks or damage to fuel lines .. if the repair was done very recently it could be a left over smell and will clear up in a little time .. if your mechanic will not recheck get a second opinion from another tech.
Oct 30, 2010 at 4:01 AM
BURNINGFIRE
  • 10 POSTS
you could also have a problem with the little backflow valve located at the front of the fuel rail where fuel goes to the injectors. It has a diaphram that is supposed to keep fuel from leaking back from the injector rail. this could even lead to fuel flooding the injectors giving a fuel odor. Have this replaced and see if this fixes the problem, it did mine.
Aug 6, 2011 at 1:27 AM
