Axel will not come out of transfer case when prying
AEBISHOP
1997 850 2.4 liter automatic non-turbo with 160,000 granny miles. I am replacing left side axle CV assembly per proceedures. The inner boot was tore
and bad. The inside joint came apart. I set it aside.
the shaft will not come out of the transfer case I am slightly prying on it to pop loose from snap ring. How hard should I pry and is there something I am missing?
7 hours latter
Ok wow would not pry off so I used a couple of wedges to have it come of straight wha la... popped off the snap ring now to the other side is the same
deal with intermediate shaft bearing involved.
Jul 8, 2007 at 1:59 AM
AEBISHOP
Passanger side have axle loose but inboard cv won't pop off snap ring. This is at the end of the intermediate shaft. This should pop off just like the drivers side right? I should not have to take intermediate bearing bracket off right? same snap ring as driver side arrangement?
Jul 8, 2007 at 8:15 AM
