1997 Volvo 850 TURBO WHINES WHEN ENG COLD
119,000 MILES • 4 CYL • FWD • AUTOMATIC
DRYNBERG
Hi Guys,
What could cause my turbo to whine for first 1-2 min if engine is cold, but no problem if it idles for about 1 in summer and two min in winter. I have flushed the oil, drained it twice and replaced with 5-20 good grade oil, including the auto transmission cooler hose drain.
Thanks,
Dan
Jul 19, 2010 at 8:34 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The turbo shaft bearings may be failing, as turbos are a highly balanced component, any small amount of wear in the bearings can start to cause problems, i would get a turbo specialist to check this out, do not attempt to dismantle or work on the turbo your self as you will stand a good chance of doing serious damage to it.
mark (mhpautos)
Jul 19, 2010 at 11:01 AM
DRYNBERG
I didn't mention that I'd replaced the turbo last year when the problem started, the whine was exactly the same with the rebuilt turbo that I installed. I think it must be something different, but what?
Jul 19, 2010 at 11:38 PM
  • 31,937 POSTS
I would have the oil supply to the turbo checked next.
mark (mhpautos)
Jul 19, 2010 at 11:41 PM
