1997 Volvo 850 Rebuilding rear brake calipers
HOME REPAIR
Brakes problem
1997 Volvo 850 Front Wheel Drive Automatic
I am ready to put the rear brake calipers back together when I noticed that the rubber boots are cracked. I have located a company (partsforvolvosonline.com) and they list the seals and boots for my car as being 40mm brake pistons. I have carfully measured the pistons, serveral times, and found that they are 38mm dia. The people at the on line store and myself are confused. Do you have any suggestions ?
Keith
Sep 13, 2010 at 7:51 AM
VOLVO SERVICE ADV
  • 175 POSTS
DEPENDING ON HOW YOU WANT TO FIX IT, IF YOU WANT TO FIX IT RIGHT, MY SUGGESTION IS THAT YOU BUY THE ASSEMBLY FROM A DEALER. IT ALL COMES TOGETHER IN THE CALIPER ASSEMBLY. SAVES THE TROUBLE OF HAVING TO TRY AND REPAIR AN OLD CALIPER THAT PROBABLY NEEDS REPLACEMENT ANYWAY
Sep 17, 2010 at 8:27 AM
