1997 Volvo 850
72,567 MILES • 6 CYL • 2WD • AUTOMATIC
JAMESK95
My Volvo 850 has a intermittent AC cooling problem. In the AUT selection the AC will cool great and after a few miles will go warm. It has fresh Freon and has no leaks. If I turn it off and let it stay in the off position and recycle both the AUT switch and the AC switch it will begin working again for a while and repeat the same thing. What's your take on this?
Thanks
Jim R
Aug 27, 2008 at 10:11 AM
2CARPRO JACK
  • 11,533 POSTS
Need to see if the a/c clutch is still engaged when it is blowing warm.If it isnt, then use atets light to see if there is power to teh a/c clutch, if it has power and isnt engaged then th eclutch assembly is bad, if no power, then get back to me and I will tell you where to start testing
Aug 28, 2008 at 9:13 AM
  • 75,988 POSTS
When it acts up-do you see the AC and Rec switch flash or comes on when ignition is turn on and flash for 20secs-if so get the ECC module scanned for code/s and comeback with it if there's any-
Aug 28, 2008 at 9:49 AM
