1996 Volvo 850 Tranny Binding
ROBERTICUS
Transmission problem
1996 Volvo 850 4 cyl Front Wheel Drive Automatic 154K miles
My vehicle and transmission ran fine until one morning I tried to start it and I put it in reverse. There was a clunking noise and the car came to a halt. I got out
there was nothing in the way. I tried to go forward with the same effect. Rocked the car back and forth to see if that old trick worked, it allowed me to move the car back into place in the driveway. I have a sport and econ switch to improve performance on this model. I always use 'sport'. Could this make a difference, or is my tranny shot or nearly done? AT fluid is full and looks OK. No heavy foaming or dirt.
Dec 28, 2008 at 6:10 AM
  • 31,937 POSTS
Hi there,
You will have to get a transmission specialist to test and report on this for you, when you say it clunk, this suggest that something has failed internally, there will have to be a few tests done to determine the exact cause of your problem.
mark (mhpautos)
Dec 28, 2008 at 9:07 AM
