Car occasionally will stall when warm and then wont resatart till it cools down (Maybe 30 minutes later). One shop replaced the mass airflow sensor & the first o2 sensor. Check engine light is on and shows p0171 & p0172. these two codes are rich & lean. I'm at a loss. Also recently the speedometer stops working sometimes. could this all be an ecm problem?
Feb 7, 2010 at 8:16 AM
