1996 Volvo 850 air conditioning not cold at high speed
1996 VOLVO 850
HAIZADHARUN
Air Conditioning problem
1996 Volvo 850 Front Wheel Drive Automatic
Dear sir,
My air conditioning is not cold if I drive the car at 120km/hour or more. Have changed the thermostat but it's still the same. Air conditioning is cold with driving below 120 km/hour. Any advice? My air conditioning mechanic also could not find the root cause.
Oct 3, 2010 at 7:43 PM
VOLVO SERVICE ADV
  • 175 POSTS
IN MOST CASES THE SPEED OF THE VEHICLE SHOULD NOT AFFECT THE OPERATION OF THE A/C SYSTEM. I AM ASSUMING THAT THE MECHANIC CHECKED THE SYSTEM FOR PROPER FREON LEVEL, IF THAT IS THE CASE, THERE MIGHT BE A COMPRESSOR PROBLEM. I HAVE SEEN THE COMPRESSORS OVER HEAT AND THEN SHUT DOWN. AFTER THE CIRCUIT COOLS DOWN, A/C WILL START WORKING AGAIN. ANY OTHER INFO YOU CAN GIVE?
Oct 4, 2010 at 3:11 AM
