1996 Volvo 850
YORKYGIRL
  • 1996 VOLVO 850
Engine Cooling problem
1996 Volvo 850 Two Wheel Drive Manual
Have just changed the radiator, however appears system is airlocked, have tried the usual ie running the engine with heater running etc but no joy. Only way to stop car overheating is to run the car with the heater on full blast, not a great idea. Am I missing something, I am assuming that it is airlocked is there a seperate point to bleed the cooling system,
or could it be something else.
Help please
Friday, May 15th, 2009 AT 6:16 PM
JIS001
  • 3,411 POSTS
Is the radiator cooling fan coming on?
Saturday, May 16th, 2009 AT 1:00 AM
YORKYGIRL
Yep fan working ok thermostat appears to be opening, if heater is on at full blast then it will run at normal running temperature but knock it off and it will go into the red
Saturday, May 16th, 2009 AT 3:07 PM
JIS001
  • 3,411 POSTS
Ok so if you turn the heater off and you let the vehicle idle your fan comes on by itself automaticly?
Sunday, May 17th, 2009 AT 5:19 PM
YORKYGIRL
Hi yep radiator fan will come on when it gets hot enough
Monday, May 18th, 2009 AT 6:24 AM
