1995 Volvo 850 Exhaust
HASSFAMILY
Engine Mechanical problem
1995 Volvo 850 Two Wheel Drive Automatic 113000 miles
There is a hole in the catalytic converter, at the front where the pipe is connected. I have a $1500 fix estimate (to do it right) $250 to 'give it a temp fix'. My thoughts are to eliminate the catalytic converter and replace with simple straight pipe. Will this effect the operation of the vehicle? If so how may the operation be effected?
Thanks!
Dec 11, 2008 at 10:56 AM
  • 75,988 POSTS
If your not affected with emission testing go for it however the downstream oxygen sensor will be giving the computer the wrong info though making it run rich and there goes goes your fuel mileage-
Dec 11, 2008 at 9:00 PM
