1995 Volvo 850 eng swap
1995 VOLVO 850
LARRY MERRILL
Engine problem
1995 Volvo 850 Front Wheel Drive Automatic 150200 miles
WE HAVE A 95 VOLVO 850 TURBO WITH A OVER HEATED AND WARPED MOTOR, WE HAVE A 98 V70 NON TURBO WITH A GOOD MOTOR THAT WE WOULD LIKE TO SWAP DO YOU KNOW IF IT WILL WORK,WE ARE WILLING TO TRANSFER ALL TURBO PARTS AND TRANSMISION. BOTH MOTORS ARE 5CYL AND LOOK A LIKE. I SENT YOU A 10.00 DONATION THANKS
Dec 11, 2007 at 8:07 AM
2CARPRO JACK
  • 11,533 POSTS
I wouldnt.... turbo and non-turbo engines are differnet inside where you cant see it. Lower compression on the turbo motor to allow for the added compression of the turbo. Most likely differnet rods, maybe a differnet crank.If you turbo a non-turbo engine you will wind up with a compression ration that is too high for pump gas, and other driveability problems
Dec 11, 2007 at 11:22 PM
