1995 Volvo 850 COOLANT LEAKAGE
GMAN001
Engine Cooling problem
1995 Volvo 850 Front Wheel Drive Automatic 177000 miles
I JUST REPLACED THE THERMSTAT AND ENGINE TEMP SENSOR AND NOW I HAVE A LEAK FROM UNDER THE PASSENGER SIDE OF THE CAR.
IT MAY BE THE WATER PUMP, BUT IT WAS NOT LEAKING BEFORE I DID THE REPLACEMENTS. CAN THAT HAPPEN? IS IT A PRESSURE ISSUE?
Nov 8, 2009 at 7:53 AM
  • 31,937 POSTS
Hi there,
You will need to do a pressure test to determine the exact location of this leak, do this a nd report what you find if you require further assistance.
mark (mhpautos)
Nov 8, 2009 at 7:57 AM
