1995 Volvo 850 brake sensor under pedal replacement
EWANM84
Electrical problem
1995 Volvo 850 2.5 miles
how do i replace the sensor switch under my brake pedal
Jul 29, 2010 at 6:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the soundproofing. Detach the electrical connectors at the switch Unscrew the locknut and remove the switch. To install: Place the new switch into position. Install the locknut and electrical connectors. After installing the new switch, it must be adjusted so that the brake lights comes ON when the brake pedal is depressed approximately 3 / 8 - 1 / 2 inches (8-14mm).
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528008cb46_1.jpg
Jul 29, 2010 at 10:09 AM
