1994 Volvo 850 stalling engine
195,000 MILES • 4 CYL • 2WD • AUTOMATIC
MATTHEWTUPE
my volvo 850 will not stay running if i let it go below 1500-2000 rpm and once it stalls it will not start back up again.
Jan 30, 2009 at 5:56 PM
  • 75,988 POSTS
Do you have a check engine light and when was the last tune-up?
Check your fuel pressure/idle air control valve/motor/ISC solenoid and TPS/MAF/MAP to include a heck on the PCV and EGR valves/vacuum leaks
Jan 30, 2009 at 6:06 PM
