The car throws oil out the fill cap and the dip stick.
Mar 13, 2009 at 5:53 AM
RACEFAN966
✓Experienced Mechanic
Ok have you done a compression test on the engine?
Mar 13, 2009 at 2:13 PM
MEGABITE787
MEMBER
Whats the normal compression for these engines, 5 cylinder non turbo. Could it be anything in the oil breather system.
Mar 14, 2009 at 8:36 AM
RACEFAN966
You could check the PCV valve and the breather system make sure it is clear and free flowing. As for compression do a compression test and tell me what you find and I will let you know if it is in spec at that time.
