i change fan switch,rely thermostat kits sitle fan is not run
Apr 13, 2008 at 3:24 PM
MIKE H R
MEMBER
turn on the a/c the fans should run with it on. if not check the fuses and if you are getting voltage to the fans themselves. If you do get voltage to the fans then check the fan itself.
Apr 14, 2008 at 10:22 AM
