1994 Volvo 850 cooling fan not runing
1994 VOLVO 850
260,000 MILES • 4 CYL • 2WD • AUTOMATIC
UMNIZAM
i change fan switch,rely thermostat kits sitle fan is not run
Apr 13, 2008 at 8:24 AM
MIKE H R
  • 3,094 POSTS
turn on the a/c the fans should run with it on. if not check the fuses and if you are getting voltage to the fans themselves. If you do get voltage to the fans then check the fan itself.
Apr 14, 2008 at 3:22 AM
