1993 Volvo 850 pOWER DOOR LOCKS
1993 VOLVO 850
269,000 MILES • 4 CYL • FWD • AUTOMATIC
RPFERNAN
My power door locks stop working. you can hear the click when you press the door lock key, and also when you pull up on the door lock stems. I also cannot open the trunk because it is locked.
What is the fix?
Jun 27, 2009 at 3:07 PM
MEXXIIYOU
Did you try opening it to by a key and do you have a child lock on your car because sometimes it is due to the child lock that you can not open the doors. To be sure so that it won't happen again try consulting your dealer. Sometimes bringing it to your dealer is the best solution for they will assist you on everything not only about the problem but they can also check the whole car.
Oct 24, 2010 at 5:48 AM
