1988 Volvo 760 Freeze Plug Leak
MCGRAWAV
Volvo 1988 760 Turbo, Engine: B230 4 Cyl, Mileage: 131000+
Recently diagnosed with a leaking freeze plug located between the engine and transmission, and before I get it fixed I was wondering how many freeze plugs are there on the engine?
If there is more than one, should I get them all fixed/replaced at the same time?
What would be a ballpark cost for such a repair?
Thank you in advance for your assistance.
Jun 15, 2007 at 2:31 PM
  • 55,781 POSTS
there are 6 freeze plugs in the engine that should all be replaced at the same time. If one is leaking the rest are right behind it.
Sep 17, 2007 at 3:31 PM
Suggested Repair
Replace all six engine freeze plugs at the same time. If one is leaking, the others are likely close behind.
Conversation Summary
The owner of a 1988 Volvo 760 Turbo with a B230 engine reported a leaking freeze plug between the engine and transmission and asked how many plugs the engine has, whether all should be replaced, and a ballpark cost. The expert said there are six freeze plugs and recommended replacing all of them together because the others are likely to fail soon. No cost estimate was given.
