1990 Volvo 760
1990 VOLVO 760
RICHARD JONES
1990 Volvo 760 4 cyl Two Wheel Drive Automatic
fuel pump dosn't work with when key is turned on ,pump works when hot wire is hooked to it. where are the pump relays located on my car? thare are two relays on lift front strute tower are they for the pump? what besides the key makes them them turn off and on? they may not be bad eather thanks
Jan 22, 2009 at 11:39 PM
VOLVOBOY760
I believe the two relays on the strut tower are for ignition circuit relay and cooling fan relay. the should be the same and are interchangeable.
Feb 2, 2009 at 12:31 PM
