1988 volvo 760 sedan 186,00 miles 4 cly turbo
BPD348
When I turn on my right hand turn signal my backup lights blink. I had noticed earlier in the day that the turn signals would not blink when activated. That problem resolved itself but resulted in the condition explained above.
Would a faulty turn signal blinker controller (i dont know the true name of it) cause this?
Feb 21, 2007 at 12:35 AM
BRUCE HUNT
  • 3,754 POSTS
I suspect grounding from corrosion or rust is more of an issue. Running a wire to the battery or a good known ground might resolve your problem.
Feb 21, 2007 at 5:09 AM
BPD348
should i run the wire from the ground which is attached to the right taillight assembly?
Feb 21, 2007 at 11:18 AM
