1987 Volvo 760 won't stay running
1987 VOLVO 760
21,000 MILES • 4 CYL • 2WD • AUTOMATIC
GOALIEDAD2252
starts ok.. idle is good but stalls or boggs down on accel.. f/p regulator replaced,plugs replaces, mass air flow disconnected and it ran worse..
Jul 24, 2009 at 6:46 AM
BUDDYCRAIGG
  • 2,262 POSTS
get a can of starting fluid and spray it in the air intake, while you are manually opening up the throttle.
see if you can get the RPMs to come up, if it does then you know you have a fuel delivery problem.
Jul 24, 2009 at 11:30 AM
