1991 Volvo 740 sticking calipers
1991 VOLVO 740
252,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRIANHUB
my front calipers where locking up after 5 miles[i sent this under brian 500 with my password but it won't let me log in no clue why] i sent a donation & caradiodoc told me to crack the mastercyl. bleeder while the brakes are locked up i did it & it freed the wheels he said the fluid in the master was nfg so i ordered 1 it will be here by sun.he won't be back till sun. so i'll let him know how i make out IF I CAN GET BACK IN YOUR SYSTEM I DON'T KNOW WHY IT TELLS ME SOMEBODY ALREADY HAS THAT NAME & PASS WORD[YEA I HAVE THE NAME & P.W. THE ONLY TIME IT LET ME IN IS WHEN I SAID I WILL DONATE.CAN SOME 1 PLEASE CHECK OUT THIS PROBLEM IT TAKES 30MIN TO GET ON THE SITE THANK YOU VERY MUCH BRIAN
Jul 9, 2010 at 1:55 PM
BMRFIXIT
  • 19,053 POSTS
Thank you
i will pass your note to the administration
as for the brakes
couple points if i may add ,and not to be over looked
flush old brake fluid
check caliper hoses as they collapse causing fluid build up in caliper behind the piston
Jul 9, 2010 at 2:23 PM
THIS IS MIKE
  • 686 POSTS
Hi Brian,
It looks like you previously asked your question using name brian50o we already have a member brian500 thats why you couldn't log in using it.
We appreciate your donation and hope we can help you
Jul 9, 2010 at 5:28 PM
