1991 Volvo 740 replacing distributor inner seal
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
SORENSONRG
I have a seal replacement kit that contains two round gaskets that replace obvious exisiting ones. I can't get the pin out of the shaft and don't know where the final seal goes. Does it go on the shaft? Do I need to remove the pin?
May 9, 2010 at 2:08 PM
2CARPRO JACK
  • 11,533 POSTS
From what I found the pin has to be driven out and it can be difficult at times.Also the housing is a cast aluminum that can break very easily.HEre is a link where you can read up alittle more volvoclub.org.uk/faq/ElectricalIgnition.html
May 11, 2010 at 1:35 PM
