1990 Volvo 740 water leak
1990 VOLVO 740
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
RODIA
The A\C blower does not shut off. the anti-freeze boils out of the tank; and ALL the water\anti-freeze leaks from the car and i have to constantly have to fill it with water.
Jun 11, 2010 at 12:44 PM
  • 31,937 POSTS
Hi there,
You need to determine the cause of the over heating, replace the thermostat, clean the radiator, have the cooling system pressure tested for leaks and get the pressure cap tested, get a head check done, this is a simple chemical test for exhaust gasses in the cooling system, if so this will be a head gasket problem.
mark (mhpautos)
Jun 11, 2010 at 5:45 PM
