A BREIF DESCRIPTION OF PROBLEM IS I WAS DRIVING ENGINE BEGAN TO LEAK OIL. THE CAR WILL START AND RUN UNTIL I HIT THE GAS.
Feb 13, 2009 at 3:06 AM
2CARPRO JACK
✓Experienced Mechanic
Thats a fairly vague description....... can you see where the oil is coming from? I wouldnt worry about how high the engine will rev if it leaks oil at a fast rate. Is the oil level full? Any check engine light? Look under the hood for anything obvious like hoses off or any cracks in the air intake boot
