1990 Volvo 740 trans problems!!!!!!!!
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
PJSNOOPER
i was putting trans fluid in my car and i put a quart of dextron2 and my car calls for type f if im correct. Well i was on the hwy and my car slowly lost its gears it is now just park. I drained the fluid out and added new stuff and it now shows on the tack the revs go up between gears but still wont move. its now parked and i dont know what to do . So my question is ... do i need a new trans or a shop to flush it? What would you do from here? thank you
Jan 12, 2008 at 8:15 PM
  • 31,937 POSTS
You will have to get it towed to a trans shop and explain exactly what you have done, i feel that that they will first flush the system & chance the filter, do a line pressure test, the Dextron may have caused some problems with internal seals, the transmission specialists will know exactly how it reacts.
Mark (mhpautos)
Jan 12, 2008 at 8:39 PM
