1990 Volvo 740 1990 740 gle wont start
LOBERRY2112
1990 Volvo 740 4 cyl Automatic 210000 miles
I started to change the cap and rotor on it as it was running rough and was told my a mechanic to start with a tune up and go from there. When we took off the cap and rotor it appeared they were newer so we put them back on. We thought that maybe the timing order was wrong so we changed it and it started but ran very rough. So we put it back to the way it was before and now it won't start at all. Please help I can't afford to take it to the shop again and I need my car for work...
Thank you VERY much..
Apr 1, 2009 at 6:42 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Firing order for GLE 1-3-4-2 rotation clockwise. Recheck connection make sure on tight at plugs and down on cap. Also check coil wire. If order good pull a plug wire hold 1/4 inch from block crank is there spark?
Let me know
Thanks for donate
Apr 1, 2009 at 7:13 AM
LOBERRY2112
thanks for answering so quickly, I will try these when I get home tonight but it would seem to me like it must be a loose wire somewhere since it started right up before we started to change it in the first place. I guess I should have not tried to do the tune up myself being a novice... but it saved me about 150 bucks doing it myself..
Apr 1, 2009 at 7:30 AM
DOCFIXIT
  • 18,828 POSTS
Well now your seasoned and next time will be better. Who knows maybe a water pump next
Apr 1, 2009 at 9:35 AM
LOBERRY2112
well when i got home from work today it seems that trying to start it so many times i have drained the battery. so i am putting in on the charger for the night and will try it again tomorrow. i guess this is why I should leave it to the pros... or maybe just to the men..
Apr 1, 2009 at 11:28 AM
DOCFIXIT
  • 18,828 POSTS
No you hang in there and I've got your back. My wife turned out to be the best carburator rebuilder I've ever seen
Apr 2, 2009 at 8:17 AM
KARENCAREN
  • 72 POSTS
Your luck you have a wife that knows a lot in cars.
By the way, Since you got your battery discharge you might want to check wirings in that part. You might get a problem again.
May 12, 2009 at 2:26 PM
DENVBRONCOS
  • 20 POSTS
The firing order doc fix it gave you is wrong. I have 2 1990 740 and a 760. Firing order from passenger side of cap to driver side is 4-3-1-2. That's why it might be running rough.
Jun 15, 2019 at 9:44 PM
