1988 Volvo 740 no fuel
1988 VOLVO 740
MISTER4U
  • 5 POSTS
Engine Mechanical problem
1988 Volvo 740 4 cyl Two Wheel Drive Automatic
I have an 88 volvo 740,i dont seem to be getting any fuel thru the fuel line going to the injecters,ive changed both fuel pumps,and fuel filter ,and fuel relay switch,can anyone help..thanks
Apr 12, 2008 at 9:29 PM
MERLIN2021
  • 17,250 POSTS
Have you check the pump's electrical connector for power? Could be a short to ground...and look in the underhood fuse/relay center for any fuel circuit fuses...if it's a 2.3 turbo, look at the fuel ballance resistor at the left front of the engine compartment.
https://images.2carpros.com/forum/automotive_pictures/62217_Relays_4.jpg
Apr 12, 2008 at 11:10 PM
MISTER4U
  • 5 POSTS
where would the fuses be located under the hood i could see a fuse center anywhere,just the one behind the ash tray?
Apr 12, 2008 at 11:16 PM
