1988 Volvo 740 Brake Switch
154,000 MILES • 4 CYL • 2WD • AUTOMATIC
JMKANE
My brake lights don't illuminate when I press the brake pedal. However the tailights work. I checked the bulb and there are two separate filiments, which both apperar to be good in every bulb. The fuses are all good. I also noticed that my gear shifter now does not lock into park when the car is off. I was wondering if the brake switch can or does effect both of these matters.
Oct 23, 2010 at 8:44 AM
  • 75,988 POSTS
Brake switch could be affecting both lights and shift interlock control system check and test
Oct 23, 2010 at 11:54 AM
