1985 Volvo 245
300,700 MILES • 4 CYL • 2WD • AUTOMATIC
RAXGMF
The car won t start at times. When you go back
in a few minutes, it starts and runs ok. One time it
just die. Now it won t start at all. The battery is new. It cranks but turn over now.
Jun 22, 2010 at 3:25 PM
  • 75,988 POSTS
Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 22, 2010 at 3:49 PM
