2001 Volvo 240 engine is missing
GARY SHEPPARD
Engine Performance problem
2001 Volvo 240 6 cyl Two Wheel Drive Automatic 60,ooo miles
at 55 to 60 m.p.h. my engine is missing
Jun 25, 2010 at 1:38 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 25, 2010 at 1:44 AM
