2000 Volvo 240 temperature idle
79,000 MILES • 4 CYL • FWD • AUTOMATIC
PRATEEMA
My volvo is running hard. I noticed the temperature idle is on the red. What is causing this? I have anti freeze and the car just came out of the shop within a month. Now when I tried to start it, it will not start.
Jan 3, 2008 at 3:36 AM
  • 75,988 POSTS
Replace the thermostat good insurance and refill the cooling system and then bleed it and see what happens-continues to get hot-get a block and pressue tests done
Jan 3, 2008 at 3:46 AM
PRATEEMA
[quote:3ffb3c4bb4="rasmataz"]Replace the thermostat good insurance and refill the cooling system and then bleed it and see what happens-continues to get hot-get a block and pressue tests done[/quote:3ffb3c4bb4]
What should I advise the shop when I get my car towed. I seem to always get ripped off. How much would somthing like this cost? So I need to get my cooling system flushed
Jan 3, 2008 at 4:02 AM
PRATEEMA
what do you think a job like this costs? So a cooling system flush?
Jan 3, 2008 at 4:09 AM
  • 75,988 POSTS
The thermostat probably will cost less than $20.00 and labor rate varies with your location could range from $85-$130.00 per hr.
Jan 3, 2008 at 6:10 AM
