1998 Volvo 240 Check Engine Light
1998 VOLVO 240
15,200 MILES • 4 CYL • FWD • AUTOMATIC
JOALICE
I was test driving this car (used) and the whole time the check engine light was stayed on. The dealer said it was a Sensor problem, but the higher the temperature rose the light consistently blinked. Even with the air-conditioning going. What might be causing this problem. It is a very clean car and runs really good to have this problem?
Mar 30, 2010 at 4:36 PM
BMRFIXIT
  • 19,053 POSTS
Blinking check engine light is an indication of misfiring and engine need to be check for tune up at 1st
Have to have the codes, an OBDII reader is needed to get the codes
Codes should indicate what sensor and what is going on
Apr 4, 2010 at 11:16 PM
