1993 Volvo 240 Won't start in wet weather
215,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNMASONBAILEY
Vehicle will not start in wet weather. Runs very well when weather is dry.
Apr 9, 2010 at 12:24 PM
  • 75,988 POSTS
Wet or Dry check if you're getting fuel or spark do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain
Apr 23, 2010 at 11:32 AM
